WiNG Controller and Access Point v7.9.5.1 CLI Reference Guide Version 7.9.5.1
> Auto-Provisioning Policy
Published November 13, 2024
Preface
About this Guide
Notational Conventions
Applicability notations
New in this Guide
Release 7.9.5.1
Release 7.9.5.0
Release 7.9.4.0
Release 7.9.3.0
Release 7.9.2.0
Release 7.9.1.0
Release 7.9.0.0
WiNG 7 Operating System Overview
CLI Overview
Log in to the WiNG Controller
CLI Command Modes and Commands
Getting Context Sensitive Help
Using the No Command
Using CLI Editing Features and Shortcuts
Moving the Cursor on the Command Line
Completing a Partial Command Name
Command Output pagination
Creating Profiles
Changing Default Profile
Configuring a Terminal Emulator to Connect to a Device Controller
Enabling Remote Administration
Configuring Telnet for Management Access
Configuring SSH for Management Access
User Exec Mode Commands
About User Exec Mode Commands
user-exec-commands
captive-portal-page-upload
change-password
clear
clock
cluster
commit
connect
crypto
create-cluster
crypto-cmp-cert-update
database
database-backup
database-restore
device-upgrade
enable
file-sync
gps (user and privi exec modes)
help
join-cluster
l2tpv3
logging
mint
no
on
opendns
page
ping
ping6
ssh
telnet
terminal
time-it
traceroute
traceroute6
virtual-machine
watch
exit
Privileged Exec Mode Commands
About Privileged Exec Mode Commands
privileged-exec-commands
archive
boot
cd
configure
copy
delete
diff
dir
disable
edit
erase
factory-reset
halt
mkdir
more
operational-mode
pwd
re-elect
reload
rename
rmdir
self
trigger-smart-sensor
upgrade
upgrade-abort
raid
no
Global Configuration Commands
global-config-commands
aaa-policy
aaa-tacacs-policy
alias
ap310
ap410
ap460
ap505
ap510
ap560
ap3000
ap3000x
ap5010
application
app-category (application-config-mode)
description (application-config-mode)
https
purview-app-category
use
no
application-group
application
description
no
application-policy
allow
deny (application-policy-config-mode)
description
enforcement-time
logging
mark
rate-limit
no
association-acl-policy
auto-provisioning-policy
bgp
ble-data-export-policy
rest (ble-data-export-commands)
no (ble-data-export-commands)
bonjour-gw-discovery-policy
allow-service
no
strict-service-vlan
bonjour-gw-forwarding-policy
bonjour-gw-query-forwarding-policy
captive-portal
captive-portal-mode-commands
access-time
access-type
accounting
bypass
connection-mode
custom-auth
data-limit
frictionless-onboarding
inactivity-timeout
ipv6
localization
logout-fqdn
oauth
php-helper
post-authentication-vlan
radius-vlan-assignment
redirection
report-royalty-application
server
simultaneous-users
terms-agreement
use (captive-portal-config-mode)
webpage
webpage-auto-upload
webpage-location
welcome-back
no
configuring-device-registration-with-dynamic-vlan-assignment
configuring WeChat Wi-Fi hotspot support in WiNG captive portal
configuring ExtremeGuest captive portal
clear
client-identity
client-identity-mode-commands
dhcp
dhcp-match-message-type
no (client-identity-config-mode)
client-identity-group
client-identity-group-mode-commands
client-identity
load
no (client-identity-group-config-mode)
clone
crypto-cmp-policy
customize
database-client-policy global-config
database-client-policy-commands
authentication
no (database-client-policy-config-mode)
database-policy global config
database-policy-config-commands
authentication
replica-set
shutdown
no (database-policy-config-mode)
device
device-categorization
device-categorization-mode-commands
mark-device
no (device-categorization-config-mode)
dhcp-server-policy
dhcpv6-server-policy
dns-whitelist
permit
no (dns-whitelist-config-mode)
end
ex3500
ex3500-time-range-config-commands
absolute
periodic
no (ex3500-time-range-config-mode)
ex3500-management-policy
ex3500-management-policy-config-commands
enable
http
memory
process-cpu
snmp-server
ssh
username
no (ex3500-management-policy-config-mode)
ex3500-qos-class-map-policy
ex3500-qos-class-map-policy config commands
description
match
rename
no (ex3500-qos-class-map-policy-config-commands)
ex3500-qos-policy-map
ex3500-qos-policy-map config commands
class
description
no (ex3500-qos-policy-map)
ex3524
ex3548
event-system-policy
event-system-policy-mode-commands
event
no (event-system-policy-config-mode)
firewall-policy
global-association-list
guest-management-policy
guest-management-policy config commands
email
guest-database-backup
guest-database-export
sms
sms-over-smtp
no (guest-management-policy-config-commands)
host
inline-password-encryption
iot-device-type-imagotag-policy
iot-device-type-imagotag-policy config commands
ap-id (iot-device-type-imagotag-policy)
channel (iot-device-type-imagotag-policy)
enable (iot-device-type-imagotag-policy)
fcc-mode (iot-device-type-imagotag-policy)
output-power (iot-device-type-imagotag-policy)
payload-size (iot-device-type-imagotag-policy)
window-size (iot-device-type-imagotag-policy)
server (iot-device-type-imagotag-policy)
ssl (iot-device-type-imagotag-policy)
no (iot-device-type-imagotag-policy)
ip
ipv6
ipv6-router-advertisement-policy
ipv6-router-advertisement-policy config commands
advertise
assist-neighbor-discovery
check-ra-consistency
dns-server
domain-name
managed-config-flag
nd-reachable-time
ns-interval
other-config-flag
ra
router-lifetime
router-preference
unicast-solicited-advertisement
no (ipv6-ra-policy-config-commands)
l2tpv3
location-policy
location-policy-config-mode commands
enable
location-key
server-host
no (location-policy-config-commands)
mac
management-policy
meshpoint
meshpoint-qos-policy
mint-policy
nac-list
nac-list-mode-commands
exclude
include
no (nac-list-config-commands)
netflow-policy
netflow-policy config commands
collector
interval
no (netflow-policy-config)
nsight-policy (global-config-mode)
nsight-policy config commands
enable
mandatory
server
no (nsight-policy-config-commands)
passpoint-policy
password-encryption
profile
purview-application-group
application
description
no
purview-application-policy
allow
deny
description
enforcement-time
logging
mark
rate-limit
no
radio-qos-policy
radius-group
radius-server-policy
radius-user-pool-policy
rename
replace
rf-domain
rf-domain-mode-commands
alias
channel-list
contact
control-vlan
controller-managed
country-code
geo-coordinates
layout
location
location-server
location-tenantid
mac-name
nsight-sensor
override-smart-rf
override-wlan
sensor-server
stats
timezone
tree-node
use (rf-domain-config-mode)
no (rf-domain-config-mode)
nx5500
nx7500
nx9000
roaming-assist-policy
role-policy
route-map
routing-policy
rtl-server-policy
rtl-server-policy-config-commands
url
no (rtl-server-policy-config-mode-commands)
schedule-policy
schedule-policy-config-commands
description
time-rule
no (schedule-policy-config-mode-commands)
self
sensor-policy
sensor-policy-config-commands
custom-scan
rssi-interval-duration
scan-mode
no (sensor-policy-config-mode-commands)
smart-rf-policy
t5
web-filter-policy
web-filter-config-commands
cache-max-recs
cache-save-interval
logging
server-host
server-unreachable
uncategorized-url
no (web-filter-policy-config-mode-commands)
wips-policy
wlan
wlan-config-mode-commands
802.11v
accounting (wlan-config-mode)
acl
answer-broadcast-probes
assoc-response
association-list
authentication-type
bridging-mode
broadcast-dhcp
broadcast-ssid
captive-portal-enforcement
client-access
client-client-communication
client-load-balancing
controller-assisted-mobility
data-rates
description
downstream-group-addressed-forwarding
dpi
eap-types
encryption-type
enforce-dhcp
fast-bss-transition
http-analyze
ip (wlan-config-mode)
ipv6 (wlan-config-mode)
kerberos
mac-authentication
multi-band-operation
nsight
opendns
owe-companion
protected-mgmt-frames
proxy-arp-mode
proxy-nd-mode
qos-map
radio-resource-measurement
radius
registration
relay-agent
service (wlan-config-context)
shutdown
ssid
t5-client-isolation
t5-security
time-based-access
use (wlan-config-mode)
vlan
vlan-pool-member
wep128
wep64
wing-extensions
wireless-client
wpa-wpa2
no (wlan-config-mode)
wlan-qos-policy
url-filter
url-filter-config-commands
blacklist
blockpage
description
whitelist
no (url-filter-config-mode-commands)
url-list
url-list-config-commands
url
description
no (url-list-config-mode-commands)
vx9000
no
About Global Configuration Mode Commands
Common Commands
About Common Commands
common-commands
clrscr
commit
exit
help
no
revert
service
show
write
Show Commands
About Show Commands
show-commands
show
adoption
bluetooth
boot
bonjour
captive-portal
captive-portal-page-upload (show commands)
cdp
classify-url
clock
cluster
cmp-factory-certs
commands
context
critical-resources
crypto
database
device-upgrade
dot1x
dpi
environmental-sensor
event-history
event-system-policy
ex3500
extdev
fabric-attach
file
file-sync
firewall
gps (show command)
global
gre
guest-registration
interface
ip
ip-access-list-stats
ipv6
ipv6-access-list
l2tpv3
lacp
ldap-agent
licenses
lldp
logging
mac-access-list-stats
mac-address-table
macauth
mac-auth-clients
mint
ntp
password-encryption
pppoe-client
privilege
radius
reload
rf-domain-manager
role
route-maps
rtls
running-config
session-changes
session-config
sessions
site-config-diff
smart-rf
smart-sensor
snmpv3 (show command)
spanning-tree
startup-config
t5
terminal
timezone
traffic-shape
upgrade-status
version
vrrp
virtual-machine
wireless
web-filter
what
wwan
Profile and Device Commands
About Profile and Device Configuration Commands
Profile Config Commands
adopter-auto-provisioning-policy-lookup
adoption
adoption-mode
antenna-id ap410e
antenna-id ap460e
antenna-id (ap510e)
antenna-id (ap560h)
alias
application-policy
area
arp
auto-learn
autogen-uniqueid
autoinstall
bridge
bridge-vlan-mode commands
bridging-mode
captive-portal
description
edge-vlan
firewall
http-analyze
ip
ipv6
l2-tunnel-broadcast-optimization
l2-tunnel-forward-additional-packet-types
mac-auth
name
registration
stateful-packet-inspection-l2
tunnel
tunnel-over-level2
no
use
captive-portal
cdp
cluster
configuration-persistence
controller
critical-resource
crypto
crypto
crypto-auto-ipsec-tunnel commands
groupid
ip
ike-lifetime
ikev2
remotegw
no
crypto-ikev1/ikev2-policy commands
dpd-keepalive
dpd-retries
isakmp-proposal
lifetime
mode
no
crypto-ikev1/ikev2-peer commands
authentication
ip
localid
remoteid
use
no
crypto-map-config-commands
crypto-map-ipsec-manual-instance
crypto-map-ipsec-isakmp-instance
crypto-remote-vpn-client commands
dhcp-peer
peer
shutdown
transform-set
no
database
device-onboard
device-upgrade
diag
dot1x
dpi
dscp-mapping
eguest-server (VX9000 only)
eguest-server (NOC Only)
email-notification
enforce-version
events
export
file-sync
floor
gre
gre concentrator
allowed-vlan
idle-timeout
gre tunnel
dscp
establishment-criteria
failover
mtu
native
no
peer
tunneled-vlan
http-analyze
interface
interface
interface-config-ge-instance
cdp
channel-group
description
dot1x (authenticator)
dot1x (supplicant)
duplex
eee
ip
ipv6
lacp
lacp-channel-group
lldp
mac-auth
no
power
qos
shutdown
spanning-tree
speed
switchport
use
interface-config-vlan-instance
crypto
description
dhcp
dhcp-relay-incoming
ip
ipv6
no
shutdown
use
interface-config-port-channel-instance
description
duplex
ip
ipv6
port-channel
qos
no
shutdown
spanning-tree
speed
switchport
use
interface-config-radio-instance
11axBSScolor
11axFILS
11axOFDMA
11axPSC
11axRNR
11axSupport
11axTWT
11axUmuschedBrcmOnly
adaptivity
aeroscout
aggregation
airtime-fairness
antenna-diversity
antenna-elevation
antenna-gain
antenna-mode
assoc-response
association-list
bridge
beacon
channel
data-rates
description
dfs-rehome
dynamic-chain-selection
ekahau
fallback-channel
guard-interval
ldpc
lock-rf-mode
max-clients
mu-mimo
no (radio-interface-config-command)
non-unicast
off-channel-scan
placement
power
probe-response
preamble-short
radio-share-mode
rate-selection
rf-mode
rifs
rts-threshold
shutdown
smart-rf
sniffer-redirect
stbc
transmit-beamforming
use
wips
wireless-client
wlan
interface-config-bluetooth-instance
beacon
description
eddystone
ibeacon
mode
shutdown
no (bluetooth-inf-config-command)
ip
ip
nat-pool-config-instance
address
no
ipv6
l2tpv3
l3e-lite-table
led
led-timeout
lldp
load-balancing
logging
mac-address-table
mac-auth
management-server
meshpoint-device
meshpoint-monitor-interval
min-misconfiguration-recovery-time
mint
neighbor-inactivity-timeout
neighbor-info-interval
no
noc
nsight
ntp
otls
offline-duration
power-config
preferred-controller-group
preferred-tunnel-controller
radius
rf-domain-manager
router
spanning-tree
traffic-class-mapping
traffic-shape
trustpoint (profile-config-mode)
tunnel-controller
usb-enable (profile/device-config-mode-commands)
use (profile/device-config-mode-commands)
vrrp
vrrp-state-check
virtual-controller
wep-shared-key-auth
ws-controller
service
zone
Device Config Commands
adoption-site
area
channel-list
contact
country-code
floor
geo-coordinates
hostname
lacp
layout-coordinates
license
location
location-server
location-tenantid
mac-name
no
nsight
override-wlan
remove-override
rsa-key
sensor-server
timezone
trustpoint (device-config-mode)
raid
AAA Policy
About AAA Policy
aaa-policy-commands
accounting
attribute
authentication
health-check
mac-address-format
proxy-attribute
server-pooling-mode
use
no
About Auto-Provisioning Policy
auto-provisioning-policy-commands
adopt
auto-create-rfd-template
default-adoption
deny
evaluate-always
redirect
upgrade
no
upgrade
Association-ACL Policy
Association-acl-policy-commands
deny
permit
no
Access-List Policy
ip-access-list
deny (ipv4-acl)
disable (ipv4-acl)
insert (ipv4-acl)
permit (ipv4-acl)
no (ipv4-acl)
mac-access-list
deny (mac-acl)
disable (mac-acl)
ex3500 (mac-acl-config-commands)
insert (mac-acl)
permit (mac-acl)
no (mac-acl)
ipv6-access-list
deny (ipv6-acl)
permit (ipv6-acl)
no (ipv6-acl)
ip-snmp-access-list
deny (ip-snmp acl)
permit (ip-snmp acl)
no (ip-snmp acl)
ex3500-ext-access-list
deny (ex3500-ext acl)
permit (ex3500-ext acl)
no (ex3500-ext acl)
ex3500-std-access-list
deny (ex3500-std acl)
permit (ex3500-std acl)
no (ex3500-std acl)
DHCP-Server Policy
dhcp-server-policy commands
bootp (dhcpv4-server-policy-config)
dhcp-class (dhcpv4-server-policy-config)
multiple-user-class (dhcpv4-class-config)
option (dhcpv4-class-config)
no (dhcpv4-class-config)
dhcp-pool (dhcpv4-server-policy-config)
address (dhcpv4-pool-config)
bootfile (dhcpv4-pool-config)
ddns (dhcpv4-pool-config)
default-router (dhcpv4-pool-config)
dns-server (dhcpv4-pool-config)
domain-name (dhcpv4-pool-config)
excluded-address (dhcpv4-pool-config)
lease (dhcpv4-pool-config)
netbios-name-server (dhcpv4-pool-config)
netbios-node-type (dhcpv4-pool-config)
network (dhcpv4-pool-config)
next-server (dhcpv4-pool-config)
option (dhcpv4-pool-config)
respond-via-unicast (dhcpv4-pool-config)
static-route (dhcpv4-pool-config)
update (dhcpv4-pool-config)
static-binding (dhcpv4-pool-config)
bootfile (dhcpv4-pool-static-binding)
client-name (dhcpv4-pool-static-binding)
default-router (dhcpv4-pool-static-binding)
dns-server (dhcpv4-pool-static-binding)
domain-name (dhcpv4-pool-static-binding)
ip-address (dhcpv4-pool-static-binding)
netbios-name-server (dhcpv4-pool-static-binding)
netbios-node-type (dhcpv4-pool-static-binding)
next-server (dhcpv4-pool-static-binding)
option (dhcpv4-pool-static-binding)
respond-via-unicast (dhcpv4-pool-static-binding)
static-route (dhcpv4-pool-static-binding)
no (dhcpv4-pool-static-binding)
no
ping (dhcpv4-server-policy-config)
option (dhcpv4-server-policy-config)
dhcp-server (dhcpv4-server-policy-config)
no (dhcpv4-server-policy-config)
dhcpv6-server-policy commands
dhcpv6-pool (dhcpv6-server-policy-config)
dns-server (dhcpv6-pool-config)
domain-name (dhcpv6-pool-config)
network (dhcpv6-pool-config)
option (dhcpv6-pool-config)
refresh-time (dhcpv6-pool-config)
sip (dhcpv6-pool-config)
no (dhcpv6-pool-config)
option (dhcpv6-server-policy-config)
restrict-vendor-options (dhcpv6-server-policy-config)
server-preference (dhcpv6-server-policy-config)
no (dhcpv6-server-policy-config)
Firewall Policy
firewall-policy-commands
acl-logging
alg
clamp
dhcp-offer-convert
dns-snoop
firewall
flow
ip
ip-mac
ipv6
ipv6-mac
logging
proxy-arp
proxy-nd
stateful-packet-inspection-12
storm-control
virtual-defragmentation
no
MiNT Policy
mint-policy-commands
level
lsp
mtu
router
udp
no
Management Policy
management-policy-commands
aaa-login
allowed-locations
banner
flash-ui
ftp
http
https
idle-session-timeout
ipv6 (management-policy)
nova (management-policy)
password-entry
privilege-mode-password
rest-server (management-policy)
restrict-access
snmp-server
ssh
t5 (management-policy)
telnet
user (management-policy)
service
no (management-policy)
RADIUS Policy
radius-group
guest
policy
rate-limit
no
authentication
bypass
chase-referral
crl-check
ldap-agent
ldap-group-verification
ldap-server
local
nas
proxy
session-resumption
termination
use
no
duration
user
no
Radio-QoS Policy
radio-qos-policy-commands
accelerated-multicast
admission-control
smart-aggregation
service
wmm
no
Role Policy
role-policy-commands
default-role
ldap-deadperiod
ldap-query
ldap-server
ldap-timeout
user-role
user-role commands
ap-location
assign
authentication-type
captive-portal
city
client-identity
company
country
department
emailid
employee-type
employeeid
encryption-type
group
memberOf
mu-mac
radius-user
ssid
state
title
use
user-defined
no (user-role-config-mode-command)
no (role-policy-config-mode-command)
Smart-RF Policy
smart-rf-policy commands
area
assignable-power
avoidance-time
channel-list
channel-width
coverage-hole-recovery
enable
group-by
interference-recovery
neighbor-recovery
select-shutdown
sensitivity
smart-ocs-monitoring
smart-sensor
smart-sensor-status-timer
no (smart-rf-policy-config-mode-command)
WIPS Policy
wips-policy-commands
ap-detection
enable
event
history-throttle-duration
interference-event
signature
signature mode commands
bssid
dst-mac
filter-ageout
frame-type
interference-event
mode
payload
src-mac
ssid-match
threshold-client
threshold-radio
no (wips-signature-config-mode-command)
use
no (wips-policy-config-mode-command)
WLAN-QoS Policy
WLAN-QOS-Policy commands
classification
multicast-mask
qos
rate-limit
svp-prioritization
voice-prioritization
wmm
no (wlan-qos-policy-config-mode-command)
L2TPv3 Policy
l2tpv3-policy-commands
cookie-size
failover-delay
force-12-path-recovery
hello-interval
reconnect-attempts
reconnect-interval
retry-attempts
retry-interval
rx-window-size
tx-window-size
no (l2tpv3-policy-config-mode-command)
l2tpv3-tunnel-commands
fast-failover
hostname
local-ip-address
mtu
peer
preempt
router-id
session
use
no (l2tpv3-tunnel-config-mode-command)
l2tpv3-manual-session-commands
local-cookie
local-ip-address
local-session-id
mtu
peer
remote-cookie
remote-session-id
traffic-source
no (l2tpv3-manual-session-config-mode-command)
Router Mode
router-mode-commands
area
area-type
authentication
range
no (area-config-mode-command)
auto-cost
default-information
ip
network
ospf
passive
redistribute
route-limit
router-id
no (router-mode-config-command)
Routing Policy
routing-policy-commands
apply-to-local-packets
logging
route-map
default-next-hop
fallback
mark
match
next-hop
no (route-map-config-mode-command)
use
no (routing-policy-config-mode-command)
AAA-TACACS Policy
aaa-tacacs-policy-commands
accounting
authentication
authorization
no (aaa-tacacs-policy-config-mode-command)
Meshpoint Policy
meshpoint-config-instance
allowed-vlans (meshpoint-config)
beacon-format (meshpoint-config)
control-vlan (meshpoint-config)
data-rates (meshpoint-config)
description (meshpoint-config)
force (meshpoint-config)
meshid (meshpoint-config)
neighbor (meshpoint-config)
root (meshpoint-config)
security-mode (meshpoint-config)
service (meshpoint-config)
shutdown (meshpoint-config)
use (meshpoint-config)
wpa2 (meshpoint-config)
no (meshpoint-config)
meshpoint-qos-policy-config-instance
accelerated-multicast (meshpoint-qos-policy)
rate-limit (meshpoint-qos-policy)
no (meshpoint-qos-policy)
meshpoint-device-config-instance
acs (meshpoint-device-config)
exclude (meshpoint-device-config)
hysteresis (meshpoint-device-config)
monitor (meshpoint-device-config)
path-method (meshpoint-device-config)
preferred (meshpoint-device-config)
root-select (meshpoint-device-config)
root (meshpoint-device-config)
no (meshpoint-device-config)
Passpoint Policy
passpoint-policy
3gpp
access-network-type
connection-capability
domain-name
hessid
internet
ip-address-type
nai-realm
eap-method
net-auth-type
operator
osu
description (osu-config-mode)
icon (osu-config-mode)
method (osu-config-mode)
nai (osu-config-mode)
name (osu-config-mode)
server-url (osu-config-mode)
no (osu-config-mode)
roam-consortium
venue
wan-metrics
no
Crypto-CMP Policy
crypto-cmp-policy-instance
ca-server
cert-key-size
cert-renewal-timeout
cross-cert-validate
hash-algorithm
subjectAltName
trustpoint
use
no
other-cmp-related-commands
use (other-cmp-related-commands)
show (other-cmp-related-commands)
Roaming Assist Policy
roaming-assist-policy commands
action
aggressiveness
detection-threshold
disassoc-time
handoff-count
handoff-threshold
monitoring-interval
sampling interval
no
Border Gateway Protocol
bgp ip-prefix-list
deny (ip-prefix-list)
permit (ip-prefix-list)
no (ip-prefix-list)
bgp ip-access-list
deny (bgp-ip-access-list)
permit (bgp-ip-access-list)
no (bgp-ip-acess-list)
bgp as-path-list
deny (bgp-as-path-list)
permit (bgp-as-path-list)
no (bgp-as-path-list)
bgp community-list
deny (bgp-community-list)
permit (bgp-community-list)
no (bgp-community-list)
bop ext-community-list
deny (bgp-ext-community-list)
permit (bgp-ext-community-list)
no (bgp-ext-community-list)
bgp route-map
description (bgp-route-map)
match (bgp-route-map)
set (bgp-route-map)
no (bgp-route-map)
bgp router-config
aggregate (bgp-router-config)
asn (bgp-router-config)
bgp (bgp-router-config)
bgp-route-limit (bgp-router-config)
distance (bgp-router-config)
ip (bgp-router-config)
network (bgp-router-config)
route-redistribute (bgp-router-config)
timers (bgp-router-config)
no (bgp-router-config)
bgp neighbor-config
activate (bgp-neighbor-config)
advertisement-interval (bgp-neighbor-config)
allowas-in (bgp-neightbor-config)
attribute-unchanged (bgp-neighbor-config)
capability (bgp-neighbor-config)
default-originate (bgp-neighbor-config)
description (bgp-neighbor-config)
disable-connected-check (bgp-neighbor-config)
dont-capability-negotiate (bgp-neighbor-config)
ebgp-multihop (bgp-neighbor-config)
enforce-multihop (bgp-neighbor-config)
local-as (bgp-neighbor-config)
maximum-prefix (bgp-neighbor-config)
next-hop-self (bgp-neighbor-config)
override-capability (bgp-neighbor-config)
passive (bgp-neighbor-config)
password (bgp-neighbor-config)
peer-group (bgp-neighbor-config)
port (bgp-neighbor-config)
remote-as (bgp-neighbor-config)
remove-private-as (bgp-neighbor-config)
route-server-client (bgp-neighbor-config)
send-community (bgp-neighbor-config)
shutdown (bgp-neighbor-config)
soft-reconfiguration (bgp-neighbor-config)
strict-capability-match (bgp-neighbor-config)
timers (bgp-neighbor-config)
unsuppress-map (bgp-neighbor-config)
update-source (bgp-neighbor-config)
use (bgp-neighbor-config)
weight (bgp-neighbor-config)
no (bgp-neighbor-config)
First-Time Creation of a Controller-Managed WLAN
Creating a RF Domain
Creating a Wireless Controller Profile
Creating an AP Profile
Creating an AP 7161 Profile
Creating a AP 7602Profile
Creating a DHCP Server Policy
Completing and Testing the Configuration
Understanding Dual Mode Capability
Auto-discovery of AP's Mode of Operation
Manually-setting AP's Mode of Operation
Using CLI to Set AP's Mode of Operation
Using GUI to Set AP's Mode of Operation
Resetting an AP's Mode of Operation
Resetting Distributed AP's Mode of Operation
Resetting Centralized AP's Mode of Operation
Introduction
Bulk 'Rev: AA' AP505/AP510 Upgrade through Virtual Controller
Bulk 'Rev:AA' AP5XX Upgrade through WiNG Controller/ExtremeCloud Appliance
Access Points Hardware and Firmware Specifications
AP3000/X Specifications
AP5010 Specifications
AP305C/CX Specifications
AP302W Specifications
AP360i/e Specifications
AP310i/e Specifications
AP410i/e Specifications
AP410C Specifications
AP460C, AP460S6C, and AP460S12C Specifications
AP460i/e Specifications
AP560h Specifications
AP560i Specifications
AP510e Specifications
AP510i Specifications
AP505i Specifications
This chapter provides an overview of auto-provisioning policy commands as well as summaries and detailed descriptions of the available commands.
